HOW TO
In an Amazon RDS for PostgreSQL geodatabase, the SDE user cannot drop connections using the geodatabase administration dialog box. When attempting that, an "Insufficient Permissions" error is returned.
Administering connections to a PostgreSQL geodatabase using ArcGIS tools requires PostgreSQL superuser privileges. In an Amazon RDS for PostgreSQL instance, the only superuser is rdsadmin, which is managed directly by Amazon. The SDE user is in the rds_superuser role, which is a pre-defined Amazon RDS role similar to the PostgreSQL superuser, but with some restrictions.
As a workaround, the SDE user, or anyone in the rds_superuser role, can manage connections to the PostgreSQL geodatabase through pgAmin using the pg_terminate_backend command.
SELECT * FROM pg_stat_activity WHERE datname = '<database_name>';
SELECT pg_terminate_backend(<pid>);
Article ID: 000017860
Get help from ArcGIS experts
Start chatting now
