HOW TO
Instructions provided describe how to save customizations to default HTML template. Certain customizations, such as a company logo, frameset modifications, colors, toolbar modifications and new or modified functions must be used for all Web sites created using the ArcIMS Designer Application. This article describes how to save customizations and create new html template (html.jar) file.
Before completing the following steps it is necessary to make sure that your machine has a full JDK (J2SDK) installed on it and not just a JRE.
Code:
//* parameters set by Designer *
var imsURL = 'http://esri_test/servlet/com.esri.esrimap.Esrimap?ServiceName=hyper_links_2';
var imsOVURL = 'http://esri_test/servlet/com.esri.esrimap.Esrimap?ServiceName=hyper_links_2';
// End of Designer set parameters
Code:
//Do not edit the following line
//DESIGNERSETSPARAMETERS
//Do not edit the above line
//End of Designer set parameters
The key to the above sequence is the word DESIGNERSETSPARAMETERS, it must be spelled exactly as above. This notifies Designer to look for the lines above and replace them with user set parameters.
Code:
<drive>:\ArcIMS\Website\Website_Name
Code:
jar -cvf myhtml.jar *.*
Code:
Code:
<drive>:\Program Files\ArcGIS\ArcIMS\Manager\Designer\templates
Article ID:000008096
Get help from ArcGIS experts
Download the Esri Support App
