HOW TO
Stops, barriers, and pushpins are stored in an XML document with a .GRF file extension. Use this document to archive, reuse, or share your stops, barriers, and pushpins with others.
1. Open or create a map (.apm file) containing a StreetMap layer with the desired stops, barriers, and pushpins.
2. Tap StreetMap Options and tap the Locations File tab.
3. Type the name of the new GRF file in the Location of the grf file text box and tap OK.
To load an existing GRF file:
1. Open or create a map (.apm file) containing a StreetMap layer.
3. Select the desired GRF file in the Location of the grf file text box and tap OK.
Get help from ArcGIS experts
Download the Esri Support App
