ERROR
Runtime error when opening .mxd files in ArcMap caused by the dllcmd32 process associated with EFAX faxing software
First Published: May 5, 2016
Error Message
When opening an .mxd file in ArcMap, the following error message may occur:
"this application has requested the runtime to terminate it in an unusual way..."
Cause
The dllcmd32 process, a process running from EFAX faxing software, generates this error. The dllcmd32.exe is the main executable for the configurable EFAX faxing module that is installed with the HP Laserjet 3100/3150 Jetsuite software.
The program is a non-essential system process, but should not be terminated unless it is suspected to be causing problems. See: WinTask Process Library - dllcmd32 for more information.
Solution or Workaround
There are two possible solutions:
  • Terminate the dllcmd32 process.
  • Remove the EFAX faxing software.
Article ID: 000008543
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
