ERROR
Runtime Error: Failed to save metadata of a feature class in an enterprise geodatabase
First Published: May 5, 2025
Last Published: September 4, 2025
Error Message
Saving edits made to metadata (edit metadata content or delete the geoprocessing history) using a Python script might result in the following error message:
RuntimeError: Failed to save metadata.
Cause
This error can be attributed to different reasons (permissions, format, etc.), but in an enterprise geodatabase, the main reason why it might fail to save metadata data, especially after deleting geoprocessing history, is that the associated feature class/database object is not registered with the geodatabase.
Metadata in a geodatabase is stored in the GDB_Items table (Documentation column) as XML. Therefore, if a feature class/database object is not registered with the geodatabase, there will be no metadata associated metadata item.
Solution or Workaround
  • Register the feature class/database object with the geodatabase if need be.
  • If registering is not needed, write the script to handle the error (use try and except functions for error handling).
Article ID: 000035643
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
