BUG
Running the Train Deep Learning Model tool with less than ten training samples (chips) returns the error ZeroDivisionError division by zero
Last Published: January 13, 2025
When running the Train Deep Learning Model tool, the error "ZeroDivisionError: division by zero" will be returned if there are less than ten training samples (chips) provided for each class of features being classified.
Cause
For example, let's say there are four training samples for one Class of features, and we use ten in the %Validation parameter.  In this case, the number of samples for validation will be 0.4, which is not valid.  The % value must be a whole number.
Workaround
The workaround for the issue is to make sure you have collected at least ten training samples for each category of feature to classify from your imagery.
Article ID: 000034256
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
