ERROR
Running scheduled Python task under a group managed service account throws an ArcGIS Pro License error
First Published: April 7, 2026
Last Published: June 26, 2026
Error Message
When running an ArcPy script as a scheduled task under a group managed service account (gMSA), the task may fail with the error:
“The Product License has not been initialized”
This applies to:
  • ArcGIS Pro Licensing
  • ArcPy scripts
  • Windows Task Scheduler
  • Group Managed Service Accounts (gMSA)
Cause
When ArcGIS Pro is authorized or configured, the license information is written to the current user’s profile (registry). A gMSA account has no ArcGIS Pro license configuration unless Pro is launched at least once under that account’s context.
As a result, when a scheduled task attempts to run a Python script that imports and uses ArcPy under a gMSA, ArcGIS Pro cannot find a valid initialized license and terminates execution.
Solution or Workaround
  1. Download PsTools and extract to a known path (for example: C:\PSTools).
    • PsExec64.exe is needed to launch Powershell with the gMSA user account.
  2. Open PowerShell ISE as Administrator.
  3. Ensure the gMSA account is a member of the local Administrators group on the machine.
    • Go to Edit Local Users and Groups > Groups > Administrators. Add the gMSA user if necessary.
  4. Start PowerShell ISE as an admin.
  5. Launch PowerShell Under the gMSA by running the following script in PowerShell ISE.
C:\PSTools\PsExec64.exe -i -u DOMAIN\gMSAAccount$ -p ~ powershell.exe
    • This opens a new PowerShell window running as the gMSA user.
    • -p ~ flag is required, as gMSAs do not have a traditional password.
  1. In the PowerShell window, verify the Active User Context; confirm the session is running under the gMSA account with the following command:
whoami
  1. From the gMSA PowerShell session, start ArcGIS Pro.
Start-Process "C:\Program Files\ArcGIS\Pro\bin\ArcGISPro.exe"
    • If necessary, click OK in the pop-up dialog box about Microsoft Edge.
  1. Configure ArcGIS Pro Licensing.
  2. Exit the application after licensing has been successfully configured.
  3. Re-run the Scheduled Task: execute the scheduled task again under the gMSA account.
    • The task should now run successfully without licensing errors.
Article ID: 000040955
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
