ERROR
Run Time Error: Insufficient Permissions
Error Message
Editing a versioned SDE geodatabase using ArcObjects returns:
Cause
Programmatic edits to an SDE geodatabase require at least one edit operation.
Solution or Workaround
Group your edits between the StartEditOperation and StopEditOperation methods. All edits can be made within a single edit operation.
Code:
'Start the Edit Operation
pEditor.StartEditing pWorkspace
pEditor.StartOperation
'Store the new feature
Dim pfeat As IFeature
Set pfeat = pFeatcls.CreateFeature
Set pfeat.Shape = tmpPoint
pfeat.Store
'Stop the Edit Operation
pEditor.StopOperation "StopOp"
pEditor.StopEditing True
Article ID: 000002720
Software:
  • ArcMap 8 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
