HOW TO
Rotate text programmatically
Summary
This article pertains to ArcGIS versions 8.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Instructions provided describe how to rotate text programmatically. When setting the Angle property on an ITextSymbol object, the text does not move because the Angle property is not implemented. This is a known issue at ArcGIS 8.1 and 8.2.
Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
Procedure
The workaround is to use the interface ITransform2D.
  1. Start ArcMap.
  2. Create a new UIButtonControl: How To: Create a new UIButtonControl​
 For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
  1. Right-click the UIButtonControl and select View Source.
  2. Copy this code into the UIButtonControl's click event.
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim pLayout As IPageLayout
Set pLayout = pMxDoc.PageLayout
Dim pGC As IGraphicsContainer
Set pGC = pLayout
Dim pFont As IFontDisp
Set pFont = New StdFont
pFont.Size = 15
pFont.Name = "Arial Black"
pFont.Bold = True
Dim pTextElem As ITextElement
Set pTextElem = New TextElement
Dim pTextSym As ITextSymbol
Set pTextSym = New TextSymbol
'''This line is ignored at ArcGIS 8.1 and 8.2
pTextSym.Angle = 45
pTextSym.Font = pFont
pTextSym.Size = pFont.Size
pTextElem.Symbol = pTextSym
pTextElem.Text = "TestText"
Dim pPoint As IPoint
Set pPoint = New Point
pPoint.X = 4
pPoint.Y = 5.5
Dim pElem As IElement
Set pElem = pTextElem
pElem.Geometry = pPoint
pGC.AddElement pElem, 0
'''''This is the workaround using angle...
Dim pTwoD As ITransform2D
Set pTwoD = pElem
pTwoD.Rotate pPoint, 0
pMxDoc.ActiveView.PartialRefresh esriViewGraphics, Nothing, Nothing
  1. Click Layout View from the View menu.
  2. Click the new button to run the code. A new text element is added near the center of the layout. The element is rotated from the horizontal.
Article ID: 000004395
Software:
  • ArcMap 8 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
