HOW TO
The following steps show how to set point symbols to a specific rotation angle.
Name the new field something descriptive, such as R_angle. Decimal places are optional.
Negative numbers are acceptable.
If you leave a record blank in the rotation field, or type in a value of 0 or nil, it will use the rotation value for the previous record.
If you highlight the corresponding feature in the view with the Select tool, you will see unexpected results; therefore, if you want a feature to display zero rotation, set its rotation value equal to 360.
Composite markers cannot be rotated.
Article ID:000004031
Get help from ArcGIS experts
Download the Esri Support App
