HOW TO
Use the Python scripts below to find the folder name for a given item in Portal for ArcGIS.
In the below example, the item ID is used to find the item and return its folder name:
#libraries
import arcgis
from arcgis.gis import GIS
from arcgis.gis import User
#variables
portalurl = "https://hostname.domain.com/portal"
username = "....."
password = "....."
#the id of the item that you want to know is in which folder
#(you can retrieve the item in any other way you find suitable)
itemid = "4f394f2cda81415294f96134220e0c7d"
#login
gis = GIS(portalurl,username,password,verify_cert=False)
#retrieve item
item = gis.content.get(itemid)
#specify user
user = User(gis,username)
#retrieve the folder of the item by searching for the item id
for f in user.folders:
list = user.items(folder=f)
for i in list:
search_id = list[list.index(i)].id
if item.id == search_id:
print(f['title'])
Item IDs are unique to the organization, so the script in the example above only prints one folder name. In the below example, the item title is used to find the item. Unlike the item ID, there can be more than one item with the same title in the organization, and the below script returns all the items with that title and their folder names:
#libraries
import arcgis
#variables
username = "........"
password = "........"
#the title of the item that you want to know is in which folder
itemtitle= "..........."
#login
#retrieve item
itemsearch = gis.content.search(query=f"title:{itemtitle}")
#specify user
#retrieve the folder of the item by searching for the item title
for i in list:
if i.title == itemtitle:
print(f"{i} is in folder {f['title']}")
Article ID: 000028966
Get help from ArcGIS experts
Start chatting now
