HOW TO
Sometimes, we want to match the used source enterprise geodatabase feature classes and enterprise geodatabase tables in the published referenced feature layer. This layer may have multiple sublayers and tables used. The below script will retrieve the sublayer/table name, its ID/index, and its source table/feature class name in the .sde connection.
Run the below script using the ArcGIS Pro Python environment:
from arcgis.gis import GIS from arcgis.features import FeatureLayerCollection import arcpy import re #Log in to ArcGIS Enterprise portalurl = 'https://hostname.esri.com/portal' username = 'admin' password = 'admin123' gis = GIS(portalurl,username,password) arcpy.SignInToPortal(portalurl,username,password) #Specify the referenced Feature Layer item ID featurelayeritem = gis.content.get('c800e0fe96b844cfb7e6a684383da43f') #Specify the workspace to be the REST URL of the feature layer arcpy.env.workspace = f"{featurelayeritem.url}" #Identify a list of all source feature classes and tables featureclasses = arcpy.ListFeatureClasses() sourcetables = arcpy.ListTables() """The above will create a list of strings with source feature classes and another for source tables used in the layer. The result will be ['L<id><featureclass>']. For examble, if the feature class is called 'Addresses', and the associated layer id is '3', it will be ['L3Addresses'].""" #The below is to retrieve layers and tables information from the web feature layer featurelayercollection = FeatureLayerCollection.fromitem(featurelayeritem) layers = featurelayercollection.properties['layers'] tables = featurelayercollection.properties['tables'] #Looping through each layer for layer in layers: #Retrieving the layer name and its id layername = layer['name'] layerid = layer['id'] #Looping through the source feature classes for featureclass in featureclasses: #Retrieving only the feature class name that starts with "L<layerid>" if featureclass.startswith(f'L{layerid}'): """Making sure that, for example, the layer wth id 33 doesn't get retrieved with the one with 3 id. So we make sure that the character after L<layerid> is a letter not a number as feature classes can only start with letters""" prefixlength = len(f'L{layerid}') if re.match(r'[A-Z,a-z]',featureclass[prefixlength:]): #Identifying the sourcename without 'l<layerid>' sourcename = featureclass[prefixlength:] #Printing the result print(f'Layer name: {layername}') print(f'Layer ID: {layerid}') print(f'Source Feature Class: {sourcename}') print('-----------------------------------') #Looping through each table for table in tables: #Retrieving the table name and its id tablename = table['name'] tableid = table['id'] #Looping through the source tables for sourcetable in sourcetables: #Retrieving only the table name that starts with "L<tableid>" if sourcetable.startswith(f'L{tableid}'): """Making sure that, for example, the table wth id 33 doesn't get retrieved with the one with 3 id. So we make sure that the character after L<tableid> is a letter not a number as feature classes can only start with letters""" prefixlength = len(f'L{tableid}') if re.match(r'[A-Z,a-z]',sourcetable[prefixlength:]): #Identifying the sourcename without 'l<tableid>' sourcename = sourcetable[prefixlength:] #Printing the result print(f'Table name: {tablename}') print(f'Table ID: {tableid}') print(f'Source Table: {sourcename}') print('-----------------------------------')
Article ID: 000032337
Get help from ArcGIS experts
Download the Esri Support App
