HOW TO
Retain elevation values when converting from a shapefile to CAD
First Published: May 5, 2016
Summary
Instructions provided describe how to retain elevation values when converting from a shapefile to CAD.
Procedure
  1. Open the attribute table of the shapefile, add a new field of type Double and name it 'Elevation'.
  2. Calculate the Elevation field equal to the field within the attribute table that contains the elevation values.
    · If the shapefile is a polyline or polygon and there is no field that contains the elevation, populate the field manually.
    · If the shapefile has a pointZ and there is no field that contains the elevation, navigate to ArcToolbox > Data Management Tools > Features > Add XY Coordinates. This creates an X,Y, and Z field within the point shapefile. Calculate the Elevation field to equal the Z field.
  3. Export the shapefile to CAD by navigating to ArcToolbox > Conversion Tools > To CAD > Export to CAD.
  4. Open the attribute table of the CAD output. The 'Elevation' field is populated.
Article ID: 000008886
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
