HOW TO
If the DB2 database is upgraded but the DB2 Spatial Extender is not, subsequent geodatabase upgrades fail with an error similar to the following:
"ERROR Creating Geodatabase tables
, Error = -51
,EXT_Error = 0
,EXT_ERROR1 = Underlying DBMS error
,EXT_ERROR2 = 00000"
Code:
$ db2 restore db gis from /u01/DB2/OldDB to /u01/DB2/NewDB
DB20000I The RESTORE DATABASE command completed successfully.
Code:
$ db2 rollforward db gis to end of logs and stop
Rollforward Status
Input database alias = gis
Number of nodes have returned status = 1
Node number = 0
Rollforward status = not pending
Next log file to be read =
Log files processed = -
Last committed transaction = 2012-07-12-07.49.14.000000 UTC
DB20000I The ROLLFORWARD command completed successfully.
Code:
$ db2stop
07/17/2012 16:35:58 0 0 SQL1064N DB2STOP processing was successful.
$ db2start
07/17/2012 16:36:03 0 0 SQL1063N DB2START processing was successful.
Code:
$ mkdir /u01/DB2/NewDB/NODE0000/SQL00001/SYSTEMTEMP
Code:
$ db2
db2 => connect to gis user db2admin using password
Database Connection Information
Database server = DB2/SUN64 9.7.4
SQL authorization ID = DB2ADMIN
Local database alias = GIS
db2 => CREATE BUFFERPOOL TEMPSYSBP32 IMMEDIATE SIZE AUTOMATIC PAGESIZE 32K
DB20000I The SQL command completed successfully.
db2 => CREATE SYSTEM TEMPORARY TABLESPACE TEMP_SYSTEM32 PAGESIZE 32k MANAGED BY SYSTEM USING (/u01/DB2/NewDB/NODE0000/SQL00001/SYSTEMTEMP') BUFFERPOOL TEMPSYSBP32
db2 => quit
DB20000I The QUIT command completed successfully.
Code:
$ db2se save_indexes gis -messagesFile /TEMP/save_indexes.log
GSE0000I The operation was completed successfully.
Code:
$ db2se upgrade gis -force 1 -messagesFile /TEMP/gse_upgrade.log
Upgrading database. Please wait ...
Code:
$ db2se restore_indexes gis -messagesFile /TEMP/restore_indexes.log
Article ID: 000011718
Get help from ArcGIS experts
Start chatting now
