PROBLEM
The Add Join command in ArcGIS Pro is grayed out and displays an error
First Published: September 16, 2025
Last Published: September 16, 2025
When working with a raster layer in ArcGIS Pro, the Add Join command may be grayed out. When hovering the cursor over the Add Join menu item, the following error message displays.
This command is currently unavailable.
Joins are not available for subtype layers or stream layers.
Join command is unavailable
Solution or Workaround
This issue can be resolved by using the Raster Calculator to round the value of pixels to the nearest integer.
  1. Open the Geoprocessing pane.
  2. Search for and open the Raster Calculator.
  3. In the function field, enter the following formula:
Int({Raster Name} + 0.5)
  1. Click Run.
  2. Confirm the new raster layer has an attribute table and is available to join.
confirming the solution
Article ID: 000034354
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
