HOW TO
The instructions provided describe how to report geodatabase versioning statistics in a SQL Server geodatabase. The SQL script provided below reports information about a versioned geodatabase in SQL Server. The output lists the number of versions, the number of versions blocking the DEFAULT version from being compressed to state 0, as well as the owner.names of the first five blocking versions, the number of states, the number of entries in the state_lineages table, and the number of rows in the versioned table and delta tables.
Follow the instructions provided below.
SET NOCOUNT ON
--Uncomment this CREATE TABLE statement and the INSERT INTO statement
--on line 150 and 151 to generate a permanent table containing adds and deletes counts.
/* create table delta_info
id int identity(1,1),
table_name nvarchar(100),
registration_id int,
adds int,
deletes int
DECLARE @versions_info_tab TABLE
ver_info_state_id int,
source_lin int,
com_anc_id int,
lin_name int,
state_id int
DECLARE @blocking_list TABLE
state_id int,
name varchar(100)
DECLARE @delta_table_info TABLE
a_table_name nvarchar(50),
d_table_name nvarchar(50),
a_table_count int,
d_table_count int
DECLARE @ver_count int = (SELECT COUNT(*) FROM sde.SDE_versions)
DECLARE @state_count int = (SELECT COUNT(*) FROM sde.sde_states)
DECLARE @state_lineages_count int = (SELECT COUNT(*) cnt FROM sde.SDE_state_lineages)
-- If the geodatabase has never been compressed, the SDE_compress_log table will not exist.
DECLARE @last_compress varchar(15)
IF EXISTS (SELECT table_name FROM INFORMATION_SCHEMA.TABLES WHERE table_schema IN ('SDE', 'DBO') AND table_name = 'SDE_compress_log')
BEGIN
SET @last_compress = CONVERT(varchar(15), (SELECT MAX(compress_end) FROM sde.SDE_compress_log), 1)
END
ELSE
BEGIN
SET @last_compress = 'No compress log table';
END
DECLARE @ver_info_state_id int, @message varchar(100) = '', @source_lin int,
@com_anc_id int, @lin_name int, @state_id int, @ver_blocking int = 0,
@cur_max_state int, @pos int, @idx int, @s1 int = 0, @s2 int = 0, @s3
int = 0, @s4 int = 0, @s5 int = 0, @blocking_ver_name nvarchar(100),
@blocking_ver_count int, @table_info_name varchar(100), @table_info_reg_id int,
@table_info_owner varchar(100), @p_stmt nvarchar(200),@a_stmt nvarchar(max),
@d_stmt nvarchar(max), @row_count int
DECLARE table_info_cur CURSOR FOR
SELECT owner, table_name, registration_id
FROM sde.sde_table_registry
WHERE sde.sde_table_registry.object_flags&8 = 8
DECLARE ver_list_cur CURSOR FOR
SELECT DISTINCT state_id
FROM sde.sde_versions
WHERE name = 'DEFAULT' and owner IN ('SDE', 'DBO')
ORDER BY state_id;
SELECT @state_id=state_id, @lin_name = lineage_name FROM sde.sde_states
WHERE state_id = (SELECT state_id FROM sde.sde_versions WHERE name = 'DEFAULT' and owner IN ('SDE', 'DBO'));
SET @cur_max_state = @state_id
PRINT '========== Versioning Statistics ================='
PRINT ''
PRINT 'Number of versions: ' + CONVERT(varchar, @ver_count)
PRINT '=============='
OPEN ver_list_cur
FETCH NEXT FROM ver_list_cur INTO @ver_info_state_id
WHILE @@FETCH_STATUS = 0
BEGIN
SELECT @row_count = COUNT(*) FROM sde.sde_state_lineages WHERE lineage_name = @lin_name AND lineage_id <= @state_id
SELECT @source_lin = lineage_name FROM sde.SDE_states where state_id = @ver_info_state_id
;WITH sel_max_lin_id AS
SELECT lineage_id FROM sde.sde_state_lineages WHERE lineage_name = @lin_name AND lineage_id <= @state_id
INTERSECT
SELECT lineage_id FROM sde.sde_state_lineages WHERE lineage_name = @source_lin AND lineage_id <= @ver_info_state_id
SELECT @com_anc_id = (SELECT MAX(lineage_id) FROM sel_max_lin_id)
INSERT INTO @versions_info_tab VALUES(@ver_info_state_id, @source_lin, @com_anc_id, @lin_name, @state_id);
END;
CLOSE ver_list_cur
-- Generate table of blocking version names
;WITH get_block_ver AS
SELECT owner+'.'+name as name, state_id FROM sde.sde_versions
WHERE state_id NOT IN
(SELECT DISTINCT lineage_id FROM sde.sde_state_lineages
WHERE lineage_name IN
(SELECT DISTINCT lineage_name FROM sde.sde_state_lineages
WHERE lineage_id IN (SELECT ver_info_state_id FROM @versions_info_tab) -- using only the values from the cursor which filters out the default version
INSERT INTO @blocking_list
SELECT state_id, name FROM get_block_ver -- WHERE state_id < @ver_info_state_id -- AND name NOT LIKE '%SYNC%'
DECLARE blocking_ver_name_cur CURSOR FOR
SELECT name FROM @blocking_list
SET @blocking_ver_count = (SELECT COUNT(*) FROM @blocking_list)
PRINT 'Number of versions blocking DEFAULT: ' + CONVERT(varchar, @blocking_ver_count)
PRINT 'Blocking Versions: '
OPEN blocking_ver_name_cur
FETCH NEXT FROM blocking_ver_name_cur INTO @blocking_ver_name
BEGIN
PRINT ' ' + @blocking_ver_name
END
CLOSE blocking_ver_name_cur
PRINT ''
PRINT 'Number of states: ' + CONVERT(varchar, @state_count)
PRINT 'Number of state lineages: ' + CONVERT(varchar, @state_lineages_count)
PRINT 'Last Compress: ' + CONVERT(varchar, @last_compress)
PRINT ''
OPEN table_info_cur
FETCH NEXT FROM table_info_cur INTO @table_info_owner, @table_info_name, @table_info_reg_id
BEGIN
DECLARE @a_count int, @d_count int
PRINT 'Table: ' + @table_info_owner + '.'+ @table_info_name + ' (' + CONVERT(varchar, @table_info_reg_id) + ')'
SET @a_stmt = N'SELECT @a_count=COUNT(*) FROM ' + @table_info_owner + '.a' + CONVERT(varchar, @table_info_reg_id)
EXEC sp_executesql @query = @a_stmt, @params = N'@a_count INT OUTPUT', @a_count = @a_count OUTPUT
SET @d_stmt = N'SELECT @d_count=COUNT(*) FROM ' + @table_info_owner + '.D' + CONVERT(varchar, @table_info_reg_id)
EXEC sp_executesql @query = @d_stmt, @params = N'@d_count INT OUTPUT', @d_count = @d_count OUTPUT
INSERT INTO @delta_table_info VALUES
@table_info_owner + '.a' + CONVERT(varchar, @table_info_reg_id),
@table_info_owner + '.D' + CONVERT(varchar, @table_info_reg_id),
@a_count,
@d_count
/* INSERT INTO dbo.delta_info (table_name, registration_id, adds, deletes)
VALUES (@table_info_name, @table_info_reg_id, @a_count, @d_count) */
PRINT 'Adds Count: ' + CONVERT(varchar, @a_count)
PRINT 'Deletes Count: ' + CONVERT(varchar, @d_count)
PRINT ''
END
CLOSE table_info_cur
DEALLOCATE ver_list_cur
DEALLOCATE blocking_ver_name_cur
DEALLOCATE table_info_cur
Sample output: ==========Versioning Statistics================= Number of versions: 2 ============== Number of versions blocking DEFAULT: 1 Blocking Versions: dbo.QA Number of states: 3577 Number of state lineages: 100015 Last Compress: 2018-01-09 Table: DBO.CONTROLCORNER (45) Adds Count: 124 Deletes Count: 124 Table: DBO.PLSSBOUNDARY (46) Adds Count: 8 Deletes Count: 8
Article ID: 000017513
Get help from ArcGIS experts
Start chatting now
