PROBLEM
Replication packages files (.crpk) used for distributed collaboration remain in the portal if the collaboration synchronization process fails
First Published: January 14, 2020
If synchronization fails in a distributed collaboration, the replication package used to move items and data between collaboration workspaces remains in the ArcGIS Enterprise portal or ArcGIS Online. If collaboration workspaces are configured to synchronize frequently and the issue that is causing synchronization to fail is not resolved, replication package files (.crpk) can quickly accumulate in your content.
Cause
Replication packages remain to allow working with Esri to troubleshoot synchronization failures, if necessary.
Solution or Workaround
After resolving synchronization issues, delete the .crpk files from My Content.
If this problem is still encountered after following these steps, please contact Esri Technical Support (for customers in the United States) or your Esri distributor (for customers outside the United States) to resolve this issue.
Article ID: 000022589
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
