PROBLEM
Note: This article pertains to ArcGIS versions 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
When using disconnected replication a deadlock situation occurs where both replicas are data receivers with the same generation numbers (in their replica properties).
This is caused by the following workflow:
Note: This should be blocked, now both replicas are senders with the same generation numbers.
Note: This issue occurs in ArcGIS versions 9.2, 9.3, and 9.3.1 only. This problem does not occur in later versions.
Article ID: 000010862
Get help from ArcGIS experts
Download the Esri Support App
