PROBLEM
If an st_geometry attribute in Oracle is renamed using the ALTER TABLE RENAME COLUMN command, the metadata for the table's attribute in the SDE st_geometry_columns and st_geometry_index table is not updated to reflect the new attribute name. If the metadata does not correctly reflect the table's st_geometry attributes name, various st_geometry functionality can fail.
The following example demonstrates how to rename an st_geometry attribute using the ALTER TABLE command:
Code:
SQL> ALTER TABLE streets RENAME COLUMN str_shp TO shape;
Table altered.
The cause of the problem is Oracle bug 7190948. See Oracle's MetaLink in the Related Information section below for additional information.
Article ID:000010229
Get help from ArcGIS experts
Download the Esri Support App
