HOW TO
Rename a network dataset and participant feature classes in ArcGIS Pro
First Published: February 10, 2025
Last Published: February 10, 2025
Summary
In ArcGIS Pro, renaming a network dataset and its associated feature classes is not directly possible due to the underlying structure of network datasets. Network datasets comprise tightly coupled elements such as relationship classes and network attributes. These components are dependent on the exact names and structure of the dataset and renaming a network dataset or participant layers can potentially corrupt it and make it unusable. This can be seen by opening the Network Dataset Properties and the error "Cannot connect to database" displays.
Cause
Network datasets are composed of tightly coupled elements such as relationship classes and network attributes. These components are dependent on the exact names and structure of the dataset. Renaming a network dataset directly can break these relationships, potentially corrupting the data or making the dataset unusable. Therefore, renaming is not allowed to ensure that the relationships and data integrity within the network dataset are preserved.
Procedure
To rename a network dataset and its feature classes, follow the steps below:
  1. Delete the network dataset:
    • Before renaming, the existing network dataset must be deleted. This breaks the connections between the feature classes and the network dataset, allowing you to rename the feature classes.
  2. Rename the feature classes:
    • Once the network dataset is deleted, rename the feature classes inside the geodatabase as needed.
  3. Re-create the network dataset:
  4. Test the new network dataset:
    Perform network analysis operations on the newly created dataset to verify that all relationships and functionality are intact.
Article ID: 000033730
Software:
  • ArcGIS Pro
  • ArcGIS Network Analyst
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
