HOW TO
The Remove rasters from Mosaic Dataset tool does not have the option for spatial query. The code below illustrates the use of ArcPy to remove rasters based on a polygon area of interest.
Code:
import arcpy
from arcpy import env
#set variables
env.workspace = r"D:\Documents\Northwest.gdb"
clipShape = "parks"
mosaicDataset = "CityOfPortland"
# Make a mosaic layer to be able to select the footprint
arcpy.MakeMosaicLayer_management(mosaicDataset, "mdlayer")
# Select the footprint based on polygon clipShape using the intersect method
arcpy.SelectLayerByLocation_management("mdlayer", "INTERSECT", clipShape)
# Run the remove rasters tool without any query on the selection
arcpy.RemoveRastersFromMosaicDataset_management("mdlayer", "#", "UPDATE_BOUNDARY", "MARK_OVERVIEW_ITEMS")
Article ID: 000011807
Get help from ArcGIS experts
Start chatting now
