HOW TO
This article provides a script that will remove duplicate records from a table for a user specified field.
Code:
'-- RemoveDuplicateRecords.ave
'-- This script will determine if duplicate records exist within a table based
'-- on a user-defined field. It will create a new table without the duplicate records.
'-- You will need to have a table document as the active document when running
'-- this script. It will prompt you for the field to compare values on in order to determine
'-- if it is a duplicate record. It will also prompt you for an output filename.
atable = av.getactivedoc
avtab = atable.getvtab
selbitmap = avtab.getselection
'-- Set all bits in the selection bitmap to false
selbitmap.clearall
'-- Determine a field to run the comparison on
'-- Sort the field in ascending order
afieldlist = avtab.getfields
sortfield = msgbox.choiceasstring(afieldlist, "Please choose a field that will determine if duplicate records exist:", "Fields")
atable.sort(sortfield, false)
'-- Create a starting value of nil to compare table values
'-- If your table has nil values, you can choose a new value
avalue = nil
'-- For each record in a Vtab
'-- Convert aRowNumber in the table to a record number in the VTab of the table
'-- The record number will now be dependent on the order of the sort field
'-- Compare each record's value string to the previous record's value string
'-- Each record that is determined not to be a duplicate is set to TRUE in
'-- the Selection Bitmap for the Vtab
for each rec in avtab
arecordnumber = atable.convertrowtorecord(rec)
comparisonstring = avtab.returnvaluestring(sortfield, arecordnumber)
if (comparisonstring = avalue) then
continue
avalue = comparisonstring
else
selbitmap.set(arecordnumber)
end
end
avtab.updateselection
'-- Export the selected records to a new file (anewVtab)
'-- Create and open a new table based on the newVtab
newFileName = FileDialog.Put ("$HOME\newfile.dbf".asfilename, "*.dbf",
"Choose output filename!")
anewvtab = avtab.export(newFileName, dbase, true)
anewtable = table.make(anewvtab)
anewtable.setname(atable.getname++"Without Duplicate Records")
'av.getproject.adddoc(atable)
anewtable.getwin.open
selbitmap.clearall
Article ID:000004018
Get help from ArcGIS experts
Download the Esri Support App
