HOW TO
In certain scenarios, it may be necessary to remove an ArcGIS Enterprise server's default printing service layout templates or print formats from the available options in the drop-down list on the Windows OS.
Caution:
From the Esri Technical Support perspective, we highly recommend creating and publishing custom print services rather than modifying the default out-of-the-box printing service, as modifying/tampering with this service causes the service to become outside of the scope of support.
The default printing service's layout templates drop-down list choices can be found and modified through the toolbox for the printing service in the ArcGIS Server's installation directories.
CAUTION:
Make sure to take a backup copy of the PrintingTools.tbx file if it is necessary to revert back to the original printing tool or if any issues occur.
This procedure uses ArcGIS Pro to explore and modify the print service's toolbox being referenced by ArcGIS Server:
<ArcGIS Server Installation Directory>\framework\runtime\ArcGIS\Resources\ArcToolBox\Services
Note: If you do not have an ArcGIS Pro installed on the ArcGIS Server machine and cannot connect from an ArcGIS Pro client, you can take the PrintingTools.tbx as a copy to a machine that ArcGIS Pro can connect to via a folder connection and proceed with the same modifications, and then replace the toolbox manually in the directory by overwriting/copy-paste.
The deleted layout templates will no longer appear in the choices list when consuming the printing service in web applications or Map Viewer.
Article ID: 000032742
Get help from ArcGIS experts
Start chatting now
