ERROR
Registering a table with an enterprise geodatabase fails with Error: 999999: Something unexpected caused the tool to fail
Error Message
When registering a table stored in a SQL Server Enterprise Geodatabase version 10.9.1 with the geodatabase using ArcGIS Pro 3.2 the process fails with the following error:
999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (https://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
error message as shown in the user interface
Cause
The dataset contains fields of type Big Integer.
Dataset showing Big Integer Data Type
data source showing 64-bit ObjectID
11.2.0 is the minimum enterprise geodatabase version to support 64-bit object IDsbig integers, date only, time only, and timestamp with offset data types. These data types are not supported by earlier geodatabase versions. See: Client and geodatabase compatibility
Solution or Workaround
There are two ways to resolve the error:
  • Re-create the data using integers instead of big integers before registering the the data with the enterprise geodatabase.
  • Upgrade the Enterprise Geodatabase to 11.2 or newer.
Article ID: 000033962
Software:
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
