HOW TO
Register an enterprise geodatabase to ArcGIS Server using the ArcGIS API of Python
First Published: November 26, 2025
Last Published: June 18, 2026
Summary
This article provides a step-by-step guide on how to register an enterprise geodatabase as a data store item to an ArcGIS Server using the ArcGIS API for Python. The script utilizes the arcgis library to connect to the ArcGIS Server Admin API and register a new enterprise geodatabase (EGDB).
Before running the script, ensure you meet the following requirements:
  • Access to an ArcGIS Server with administrative privileges
  • The necessary connection details for your enterprise geodatabase
  • Ensure the arcgis package is installed in your Python environment
Procedure
The steps describe how to register a new enterprise geodatabase using the add method within the class “arcgis.gis.Datastore”:
  1. Import the necessary libraries.
import arcgis
import json
from arcgis.gis import GIS
from arcgis.gis.server import Server
  1. Specify the ArcGIS Server details.
server_admin_url = '<server admin URL>'
gis = arcgis.gis.GIS(url=r'<portal url>', username='<portal admin username>', password='<portal admin password>')
gis_server = Server(server_admin_url, gis)
  1. Accessing the data store path from the ArcGIS Server Admin API.
gis_server.datastores
  1. Create a dictionary representing the data item with the name of the item to be added on the server:
itemDict = {
  "path": "/enterpriseDatabases/datastore_name",
  "type": "egdb",
  "totalRefCount": 0,
  "info": {
    "dataStoreConnectionType": "shared",
    "isManaged": False,
    "connectionString": "<the encrypted connection string for the ArcGIS Server to connect to enterprise database>",
  1. Register the data store item:
gis_server.datastores.add(itemDict)
The connection string parameter should appear as shown below, and it is generated automatically when we attempt to register a datastore using the .sde file from the ArcGIS Server Manager. Additionally, ArcGIS Pro tools can also be used to create this encrypted connection string.
“ENCRYPTED_PASSWORD_UTF8=00022e684b754f4f38634b4f7a613951525a61737933442b77673d3d2a00;ENCRYPTED_P
ASSWORD=00022e6879685a4a542b6f64422f2f75416c44584a6a2f4341773d3d2a00;SERVER=aspen;INSTANCE=sde:postg
resql:aspen;DBCLIENT=postgresql;DB_CONNECTION_PROPERTIES=aspen;DATABASE=pglakehume;USER=sde;VERSION=s
de.DEFAULT;AUTHENTICATION_MODE=DBMS”
Article ID: 000039240
Software:
  • ArcGIS Server
  • ArcGIS API for Python
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
