HOW TO
Instructions provided describe the steps to convert a DB2 spatial table into a feature class to be used by ArcGIS.
Code:
db2 => CREATE TABLE "MAP"."POLY"
("POLY_ID" BIGINT , "POLY_TYPE" INTEGER , "REASON_COD" INTEGER , "SOURCE_" INTEGER ,
"SOURCE_SUB" INTEGER , "QUAL" INTEGER , "ASSR_POLY_" BIGINT , "RCD_POLY_I" BIGINT ,
"TRNX_UID" VARCHAR(5) , "TRNX_DATE" DATE , "TRNX_PROG" VARCHAR(8) , "STOP_DATE" DATE ,
"SHAPE" "DB2GSE "."ST_MULTIPOLYGON" , "OBJECTID" INTEGER NOT NULL WITH DEFAULT 0 )
IN "SDEDB2" INDEX IN "SDEINDEX" LONG IN "SDELOBS"
Code:
c:\>sdelayer -o register -l map.poly,shape -e a+
-C objectid,SDE -u map -p map -i 5920
- R <srid used to register the table with the Spatial Extender>
The -R option must be specified. If it is not, data cannot be loaded into the feature class.
The table has to be unregistered then registered again before the data can be loaded.
Code:
c:>sdelayer -o delete -l map.poly,shape -u map -p map -i 5920
Article ID:000009910
Get help from ArcGIS experts
Download the Esri Support App
