PROBLEM
Refreshing a MapService does not capture updated shapefile data
I updated my shapefile to add a new field. Why does refreshing a MapService not capture updated shapefile information?
Cause
The data source fields are only read in at load time when you first start a MapService.
Solution or Workaround
If you have only one MapService using the shapefile, refresh the MapService. In Manager, you can click Properties for the MapService and then click OK. In the Administrator, click the refresh button for the MapService.
If more than one MapService is using the shapefile, you need to remove all MapServices that use that shapefile, and then add them again.
Article ID:000002190
Software:
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
