HOW TO
When printing with ArcMap, temporary print files are created in %TEMP%. Printing errors can occur if %TEMP% is on a drive with inadequate space.
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
d:\temp
Note: ArcPress for ArcMap also writes all temporary files to PRINTTMPDIR even if an APRESSTMPDIR is set.
d:\temp
Warning: Be very careful not to modify anything in the registry except for the entries indicated above. The integrity of the operating system can be seriously compromised by modifying the wrong entries.
Article ID: 000002155
Get help from ArcGIS experts
Start chatting now
