PROBLEM
Reclassify tool stops responding in ArcMap
First Published: May 5, 2016
The Reclassify tool in the Spatial Analyst toolbar enables reclassification of the raster values. In some instances, the tool causes ArcMap to stop responding.
Cause
The issue occurs when background geoprocessing is enabled.
Solution or Workaround
Run the Reclassify tool in the foreground by disabling background processing. To do this in ArcMap, follow the steps provided below:
  1. Go to the Geoprocessing menu.
  2. Click Geoprocessing Options.
  3. In the Geoprocessing Options dialog box, navigate to Background Processing, and uncheck the Enable check box.
    [O-Image]
Article ID: 000012206
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
