ERROR
You are not authorized for an ArcGIS Reality Studio Advanced Single Use license. Please select a different base level or authorize an ArcGIS Reality Studio Advanced Single Use license
First Published: September 15, 2026
Last Published: September 15, 2026
Error Message
When attempting to authorize an ArcGIS Reality Studio Single Use license, the following error message is returned:
"You are not authorized for an ArcGIS Reality Studio Advanced Single Use license. Please select a different base level or authorize an ArcGIS Reality Studio Advanced Single Use license."
The error occurs:
  • Regardless of whether the authorization is performed by manually entering the authorization number or by using an authorization file.
  • Regardless of whether other Esri products are installed on the device.
Cause
Reality Studio from the 2025.x versions require licenses that start with SNG.
Solution or Workaround
  • Check whether the user has a valid authorization number beginning with 'SNG'.
  • If the authorization number begins with ESU, contact Customer Service to:
    • Verify that the user is entitled to ArcGIS Reality Studio version 2025.x or later.
    • If the user is entitled to the current version of the software (2025.x or later), Customer Service should request that the correct authorization number be added to the customer's account.
  • Verify that the user has received the correct authorization number and that it is visible in the customer's My Esri account.
Article ID: 000043347
Software:
  • ArcGIS Reality Studio
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
