HOW TO
BEGIN_USGS_DOQ_HEADER *
QUADRANGLE_NAME "RIVIERA BEACH" 3.45 or 7.5-min. name*
QUADRANT SW quadrant indicator if cell size = 3.75-minutes*
WEST_LONGITUDE -80 7 30.000 signed deg min sec SDDD MM SS.SSS*
EAST_LONGITUDE -80 3 45.000 signed deg min sec SDDD MM SS.SSS*
NORTH_LATITUDE 26 48 45.000 signed deg min sec SDDD MM SS.SSS*
SOUTH_LATITUDE 26 45 0.000 signed deg min sec SDDD MM SS.SSS*
PRODUCTION_DATE 1996 5 14 yyyy mm dd*
RASTER_ORDER LEFT_RIGHT/TOP_BOTTOM video display order*
BAND_ORGANIZATION BIP single file or BSQ, or BIL or BIP*
BAND_CONTENT RED black&white or red green blue*
BAND_CONTENT GREEN black&white or red green blue*
BAND_CONTENT BLUE black&white or red green blue*
BITS_PER_PIXEL 8 radiometric resolution*
SAMPLES_AND_LINES 6889 7608 number of columns and rows*
HORIZONTAL_DATUM NAD83 primary horizontal datum*
HORIZONTAL_COORDINATE_SYSTEM UTM *
COORDINATE_ZONE 17 coordinate system zone number*
HORIZONTAL_UNITS METERS coordinate system units*
HORIZONTAL_RESOLUTION 1.00 pixel horiz. ground sample distance*
SECONDARY_HORIZONTAL_DATUM NAD27 secondary horizontal datum*
XY_ORIGIN 586657.000 2966350.000 coord. of upper left pixel pri. datum*
SECONDARY_XY_ORIGIN 586635.552 2966145.866 coord upper left pixel sec datum*
NATION US nation code*
STATE FL state fip code*
NW_QUAD_CORNER_XY 586958.828 2965967.697 XY coords. of pri. NW quad corner*
NE_QUAD_CORNER_XY 593170.493 2966012.018 XY coords. of pri. NE quad corner*
SE_QUAD_CORNER_XY 593221.537 2959089.228 XY coords. of pri. SE quad corner*
SW_QUAD_CORNER_XY 587006.468 2959044.978 XY coords. of pri. SW quad corner*
SECONDARY_NW_QUAD_XY 586960.432 2965801.317 XY coords. - sec. NW quad cor.*
SECONDARY_NE_QUAD_XY 593172.212 2965845.639 XY coords. - sec. NE quad cor.*
SECONDARY_SE_QUAD_XY 593223.254 2958923.135 XY coords. - sec. SE quad cor.*
SECONDARY_SW_QUAD_XY 587008.071 2958878.884 XY coords. - sec. SW quad cor.*
RMSE_XY 0.70 doq horiz. accuracy*
IMAGE_SOURCE "COLOR INFRA-RED FILM" b&w, cir, natural color, other*
SOURCE_IMAGE_ID "NAPP 6966 108" source image id*
SOURCE_IMAGE_DATE 1995 1 26 source image date as yyyy mm dd*
SOURCE_DEM_DATE 1996 5 14 source dem date yyyy mm dd*
AGENCY "WESTERN MAPPING CENTER (WMC)" oversight agency*
PRODUCER "Science Applications International" producer/contractor*
PRODUCTION_SYSTEM "GIS/MAGIC" production system*
STANDARD_VERSION 1996 12 version of DOQ standard*
METADATA_DATE 1997 6 29 date created or changed, yyyy mm dd*
DATA_FILE_SIZE 157255203 data set size in bytes*
BYTE_COUNT 20667 header byte count*
FORMAT EXTENTION
BIL .blw
BIP .bpw
BSQ .bqw
Information about building a world file can be found in the ArcDoc section: Cartography > Image integration > Registering an image to real-world coordinates. Detailed information about what each parameter of the DOQQ header represents can be found at the site below.
Article ID:000001325
Get help from ArcGIS experts
Download the Esri Support App
