Summary
                    If the application configuration file gets deleted, the instructions provided describe how to re-create it.
                        Procedure
- From the Windows Start menu, select ArcGIS Explorer > Application Configuration Manager.
 - In the 'ArcGIS Explorer Application Configuration' dialog box, select 'Create a new application configuration'.
 - In the 'Create Application Configuration' dialog box, specify the name and file name for the new application configuration. Provide values for 'Name:' and 'File:'. Select 'Create'.
 - In the 'ArcGIS Explorer Application Configuration' dialog box, select 'Preview', which launches ArcGIS Explorer.
 - In ArcGIS Explorer, using the pearl (the globe icon), select 'Set Application Configuration'.
 - In the 'Application Configuration' dialog box select 'Browse...'. Select the newly created application configuration filename.
 - Select 'Update'.
 - Select 'Restart Now'. This opens ArcGIS Explorer.
