ERROR
TOPOGRID with a contour coverage returns the following error:
RDCONT - too many contour arcs
FATAL ERROR
Bailing out of TOPOGRID
The contours are too dense for the output cell size specified. The number of contour lines being interpolated for a single output cell exceeds an internal estimate. The RDCONT routine reads arcs of the contour coverage. It estimates the size of internal programming arrays necessary to hold arc x,y coordinates. This estimate is based on the number of rows and columns of the output grid. There is no method to determine if this limit will be reached before running TOPOGRID.
The majority of the TOPOGRID error messages, such as TOO MANY CRITICAL POINTS, TOO MANY CONTOUR POINTS, or TOO MANY CONTOUR ARCS, are due to contour data that is too dense for the output resolution. TOPOGRID is being used as a resampling tool, for which it is not designed.
See the "Informative messages" section of the TOPOGRID "Discussion" section in the ArcInfo online ArcDoc.
Article ID:000002443
Get help from ArcGIS experts
Download the Esri Support App
