ERROR
Raster layers in the map service prevent the application from starting up when using the ArcGIS Server plug-in for Eclipse IDE
Error Message
Adding a map service that contains raster layers to a WebADF project in Eclipse, using the ArcGIS Server plug-in wizards, causes the application to encounter the following fatal exception:
javax.faces.FacesException: The scope of the referenced object: '#{}' is shorter than the referring object
Cause
The faces-config.xml file generated by the ArcGIS Server plug-in generates a managed-bean representing the LayerDefinition for each raster layer in the map service. These managed-beans contain empty references, '#{}', for the 'renderer' and 'highlightRenderer' properties, which prevents the application from starting up.
<managed-bean>
<managed-bean-name>rasterLayer</managed-bean-name>
<managed-bean-class>com.esri.adf.web.data.query.LayerDefinition</managed-bean-class>
<managed-property>
<property-name>renderer</property-name>
<value>#{}</value>
</managed-property>
<managed-property>
<property-name>highlightRenderer</property-name>
<value>#{}</value>
</managed-property>
</managed-bean>
Solution or Workaround
  1. Delete the managed-bean definitions for raster layers from faces-config.xml.
  2. Delete references to these managed-beans from the WebQuery managed-bean.
Article ID: 000010270
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
