BUG
After publishing a map the published map is empty or has missing data frames.
ArcReader may crash when trying to open the published map.
Publisher is unable to work with grouped data frames. In ArcMap's layout view when multiple data frames are selected and grouped, the data frames are not published.
If all of the data frames are in the same group, ArcReader opens the published map, but it appears empty. If the map contains a mixture of grouped and ungrouped data frames, the ungrouped data frames display in ArcReader. In this mixed state, if a dataframe in the group is the active data frame, ArcReader crashes while trying to open the published map.
Article ID:000007659
Get help from ArcGIS experts
Download the Esri Support App
