PROBLEM
When a hosted feature service is published to Portal for ArcGIS, publishing fails if the name of the CSV file, shapefile, or feature class being published is in a language that does not match the database collation of the portal's hosting server.
Hosted feature service data is stored in tables in the hosting server's geodatabase. The geodatabase uses the database's collation to read the name of the table. If the table name is stored in a language that does not match the database collation, the name cannot be properly read by the geodatabase.
Article ID: 000011916
Get help from ArcGIS experts
Start chatting now
