BUG
Prune Branch History with an empty ‘Prune Before Date’ ignores referenced moments resulting in additional rows being pruned
First Published: March 17, 2026
Last Published: March 17, 2026
Executing the Prune Branch History geoprocessing tool without a value for the ‘Prune Before Date’ parameter can incorrectly prune additional rows in ArcGIS Pro 3.5 and 3.6. When this issue is encountered, features can disappear from versions if the feature was updated or deleted in the Default version. An additional side effect is that reconcile may fail to detect conflicts and/or replicas can fail to detect changes.
Cause
When the Prune Branch History geoprocessing tool is executed without a ‘Prune Before Date’ parameter, the tool should detect the oldest referenced moment and use this moment for the prune operation. Because of this issue, the Prune Branch History tool is ignoring the referenced moments and uses the current moment and incorrectly deletes dependent rows.
Workaround
Specifying a valid ‘Prune Before Date’ moment will ensure the correct behavior.
ArcGIS Pro 3.7 and upcoming ArcGIS Pro 3.6.x and ArcGIS Pro 3.5.x releases will correctly use the oldest referenced moment for the operation.
Article ID: 000040852
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
