PROBLEM
The example in this article shows how to reduce the differences between the output of the Projector sample extension and the ArcInfo PROJECT command.
This is related to mismatches in either spheroid, datum, or both. When projecting in ArcInfo, the default spheroid for UTM and the two Stateplane coordinate systems is Clarke 1866, whereas in ArcView it is GRS80 for UTM, and Stateplane NAD83 and Clarke 1866 for Stateplane NAD27.
For example, for a coverage with the following parameters:
Stateplane California Zone VI (3401) NAD83
Spheroid Clarke1866
Units Feet
Code:
INPUT
PROJECTION STATEPLANE
ZONE 3401
DATUM NAD83
UNITS FEET
OUTPUT
PROJECTION UTM
ZONE 11
UNITS METERS
PARAMETERS
END
Starting with the same Stateplane coverage in ArcView, use the following parameters for projecting it into UTM:
Code:
INPUT
Category - Stateplane NAD83
Type - Calif. Zone VI
OUTPUT
Category - UTM
Type - Zone 11
Even if the output spheroid is set to Clarke 1866, the results will not match ArcInfo. The Projector extension does not support datum transformations. It is necessary to use the Datum Conversion extension or the NADCON extension available from ArcScripts.
Get help from ArcGIS experts
Download the Esri Support App
