HOW TO
Code:
'------------ DD2UTM.AVE ------------
'--- This script takes a table of points in DD and projects them
'--- into UTM coordinates for a user-defined Zone.
'-- Each UTM Zone has an X-coordinate which
'-- extends from 0 to 1,000,000 meters, where 500,000 is the false easting
'-- coordinate for the central meridian, although the actual coordinates
'-- rarely get as low as 0, nor as high as 1,000,000, otherwise the
'-- coordinates would actually fall into an adjacent UTM Zone.
'-- Each UTM Zone for the Northern Hemisphere has a Y-coordinate which
'-- extends from 0 at the equator to 10,000,000 meters at the North Pole.
'-- Hence, when I create the Rectangle below, the X extends from 0 to
'-- 1 million, and the Y extends from 0 to 10 million.
'-- Then the 'Trnmerc.Make' request turns the rectangle into a UTM
myRect = Rect.Make(0@0,1000000@10000000)
myUTM = Trnmerc.Make(myRect)
a = MsgBox.Input("Enter the UTM Zone into which"+NL+
"you want to project the points.",
"Zone Choice","")
if (a = nil) then
return nil
end
'-- Conversion factor to turn a UTM Zone into its Central Meridian
b = ((a.AsNumber * 6) - 183)
myUTM.SetCentralMeridian(b)
myUTM.SetFalseEasting(500000)
myUTM.SetFalseNorthing(0)
myUTM.SetReferenceLatitude(0)
myUTM.SetScale(0.9996)
theDocList=av.GetProject.GetDocs
theTabList=List.Make
for each d in theDocList
if (d.Is(Table))
then
theTabList.Add(d)
end '-- is table
end '-- for each d
theSelTab=MsgBox.Choice(theTabList,
"Choose the table that contains the DD coord that you want to project",
"Table Choice")
if (theSelTab = nil) then
return nil
end
theVtab=theSelTab.GetVTab
theFields=theVtab.GetFields
theDDXfld=MsgBox.Choice(theFields,
"Select the field which contains the X-longitude coordinate",
"Where is X?")
theDDYfld=MsgBox.Choice(theFields,
"Select the field which contains the Y-Latitude coordinate",
"Where is Y?")
theNewDDXfld=Field.Make("XlongDD",#FIELD_DECIMAL,12,6)
theNewDDYfld=Field.Make("YlatDD",#FIELD_DECIMAL,12,6)
theNewUTMXfld=Field.Make("XlongUTM",#FIELD_DECIMAL,16,2)
theNewUTMYfld=Field.Make("YlatUTM",#FIELD_DECIMAL,16,2)
theNewFldList={theNewDDXfld,theNewDDYfld,theNewUTMXfld,theNewUTMYfld}
theNewFile=FileDialog.Put("*.dbf".AsFileName,"dBASE Files",
"Save dBASE table file")
if (theNewFile = nil) then
return nil
end
theNewVTab=VTab.MakeNew(theNewFile,dBASE)
theNewVTab.AddFields(theNewFldList)
for each rec in theVtab
theDDXval=theVtab.ReturnValue(theDDXfld,rec)
theDDYval=theVtab.ReturnValue(theDDYfld,rec)
theNewrec=theNewVTab.AddRecord
theNewVTab.SetValue(theNewDDXfld,theNewrec,theDDXval)
theNewVTab.SetValue(theNewDDYfld,theNewrec,theDDYval)
theDDpoint=Point.Make(theDDXval,theDDYval)
myUTM.ProjectPt(theDDpoint)
theUTMXval=theDDpoint.GetX
theUTMYval=theDDpoint.GetY
theNewVTab.SetValue(theNewUTMXfld,theNewrec,theUTMXval)
theNewVTab.SetValue(theNewUTMYfld,theNewrec,theUTMYval)
end
t = Table.Make(theNewVTab)
t.SetName(theNewVTab.GetName)
t.GetWin.Open
t.StopEditing
'------------ End of Script ------------
You may want to modify this script so that it makes the user select a unique ID field from the first table in (A) above. This field can be cloned into the new table in Step 2, which then can be used as the basis for a one-to-one table join, where the new coordinate fields can be rejoined back to the original table.
Article ID:000001477
Get help from ArcGIS experts
Download the Esri Support App
