HOW TO
Note: This article pertains to ArcGIS versions 8.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
This article contains sample code that shows how to insert a scale bar into an ArcMap layout using VBA and ArcObjects.
Note: Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
Note: For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
Sub InsertScaleBar() Dim pMxDoc As IMxDocument Dim pMap As IMap Dim pGC As IGraphicsContainer Dim pElem As IElement Dim pMapFrame As IMapFrame Dim pMSFrame As IMapSurroundFrame Dim pMS As IMapSurround Dim pGeom As IGeometry Dim pEnv As IEnvelope Dim pActView As IActiveView Set pMxDoc = ThisDocument Set pGC = pMxDoc.PageLayout ' Get map frame for map of interest ' (in this case, the focus map) pGC.Reset Set pElem = pGC.Next Do While (Not pElem Is Nothing) Set pMapFrame = Nothing If (TypeOf pElem Is IMapFrame) Then Set pMapFrame = pElem If (pMapFrame.Map Is pMxDoc.FocusMap) Then Exit Do End If End If Set pElem = pGC.Next Loop If (pMapFrame Is Nothing) Then MsgBox "Couldn't find map frame" Exit Sub End If ' Create scale bar object Set pMS = New AlternatingScaleBar Set pMS.Map = pMapFrame.Map ' Create surround frame for scale bar Set pMSFrame = New MapSurroundFrame Set pMSFrame.MapFrame = pMapFrame Set pMSFrame.MapSurround = pMS ' Set the map surround frame size and position Set pEnv = New Envelope pEnv.PutCoords 2, 2, 4, 2.5 Set pElem = pMSFrame pElem.Geometry = pEnv ' Add to graphics container pGC.AddElement pMSFrame, 0 ' Refresh display pMxDoc.ActiveView.Refresh End Sub
Article ID:000004966
Get help from ArcGIS experts
Download the Esri Support App
