HOW TO
This article shows how to get the version name for the first layer in ArcMap.
Code in ThisDocument module will only run in the current map document. To store the code in all your map documents, open the Normal.mxt ThisDocument code module.
Code:
Sub GetVersion()
'Returns the version for the
'first layer in ArcMap
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pLayer As IFeatureLayer
Set pLayer = pDoc.FocusMap.Layer(0)
Dim pDataset As IDataset
Set pDataset = pLayer.FeatureClass
Dim pVersion As IVersion
Set pVersion = pDataset.Workspace
MsgBox pVersion.VersionName
End Sub
Article ID:000004953
Get help from ArcGIS experts
Download the Esri Support App
