HOW TO
This VBA sample code shows the steps required to find the path of a layer in ArcMap.
Code:
Option Explicit
Sub GetPath()
Dim pDoc As IMxDocument
Dim pLayer As ILayer
Set pDoc = ThisDocument
Set pLayer = pDoc.FocusMap.Layer(0)
pDoc.FocusMap.Layer(0) gets the first layer in the map. Layer(1) will return the second layer.
Code:
Dim pDs As IDataset
If (TypeOf pLayer Is IFeatureLayer) Or (TypeOf pLayer Is IRasterLayer) Then
' Query Interface to IGeoDataset, then to IDataset.
Dim pGD As IGeoDataset
Set pGD = pLayer
'Qi from GeoDataset to Dataset
Set pDs = pGD
ElseIf (TypeOf pLayer Is ITinLayer) Then
'Qi from Layer to TinLayer
Dim pTinLayer As ITinLayer
Set pTinLayer = pLayer
Set pDs = pTinLayer.Dataset
Else
MsgBox "Layer is not a FeatureLayer, RasterLayer, or TinLayer. Exiting..."
Exit Sub
End If
Query Interface (QI) retrieves other interfaces allowing access to the methods and properties on that interface.
Code:
'Get the Workspace
Dim pW As IWorkspace
Set pW = pDs.Workspace
MsgBox pW.PathName
End Sub
Get help from ArcGIS experts
Download the Esri Support App
