HOW TO
Note: This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
This article contains sample code that adds a neatline to the active data frame.
Note: Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
Note: For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
Sub AddNeatline()
Dim x As Double
'Change x to equal the distance of
'the neatline from extent envelope
x = 0.5
Dim pMxDoc As IMxDocument
Dim pMxApp As IMxApplication
Dim pActiveView As IActiveView
Dim pMap As IMap
Dim pPageLayout As IPageLayout
Dim pDisplay As IScreenDisplay
Dim pGC As IGraphicsContainer
Dim pElem As IElement
Dim pMapFrame As IMapFrame
Dim pEnv As IEnvelope
Dim pElemEnvelope As IEnvelope
Set pMxApp = Application
Set pMxDoc = ThisDocument
Set pPageLayout = pMxDoc.PageLayout
Set pGC = pPageLayout
Set pDisplay = pMxApp.Display
'Get Active Map name
Dim strMapName As String
strMapName = ""
Set pMap = pMxDoc.FocusMap
strMapName = pMap.Name
'Get the active map's Map Frame out of the graphics container
pGC.Reset
Set pElem = pGC.Next
Do While (Not pElem Is Nothing)
If (TypeOf pElem Is IFrameElement) Then
If (TypeOf pElem Is IMapFrame) Then
Set pMapFrame = pElem
If strMapName = pMapFrame.Map.Name Then
Set pElemEnvelope = pElem.Geometry.Envelope
Set pEnv = pMapFrame.MapBounds
End If
End If
End If
Loop
Dim pRect As IRectangleElement
Set pRect = New RectangleElement
Dim pElement As IElement
Set pElement = pRect
'Set the Neatline distance from the frame border
pElemEnvelope.XMin = pElemEnvelope.XMin - x
pElemEnvelope.YMin = pElemEnvelope.YMin - x
pElemEnvelope.XMax = pElemEnvelope.XMax + x
pElemEnvelope.YMax = pElemEnvelope.YMax + x
pElement.Geometry = pElemEnvelope
'Set the Neatline symbology
Dim pRectSym As IFillShapeElement
Set pRectSym = pRect
'Set the style of the fill symbol
Dim pFillSymbol As ISimpleFillSymbol
Dim plinesymbol As ISimpleLineSymbol
Set pFillSymbol = New SimpleFillSymbol
Set plinesymbol = pFillSymbol.Outline
pFillSymbol.Style = esriSFSHollow
'Set the outline symbol
plinesymbol.Style = esriSLSSolid
plinesymbol.Width = 6
pFillSymbol.Outline = plinesymbol
'Set it all into the element
pRectSym.Symbol = pFillSymbol
'Draw the neat line
pElement.Activate pDisplay
pGC.AddElement pRect, 0
pMxDoc.ActiveView.Refresh
End Sub
Article ID: 000004968
Get help from ArcGIS experts
Start chatting now
