HOW TO
Instructions provided demonstrate how to export all layers in the ArcMap TOC programatically.
Code in the Project's ThisDocument code module will only run in the current map document. To store the code in all map documents open the Normal.mxt > ThisDocument code module instead.
Code:
Public Sub ExportAll_TOC()
Dim pDoc As IMxDocument
Dim pEnumLayer As IEnumLayer
Dim pLayer As IFeatureLayer
Dim pName As IName
Dim pLayerSet As ISet
Dim pMap As IMap
Dim pFC As IFeatureClass
Dim pINFeatureClassName As IFeatureClassName
Dim pDataset As IDataset
Dim pInDSName As IDatasetName
Dim pFields As IFields
Dim pField As IField
Dim pGeometryDef As IGeometryDef
Dim pFeatureClassName As IFeatureClassName
Dim pOutDatasetName As IDatasetName
Dim pWorkspaceName As IWorkspaceName
Dim pExportOp As IExportOperation
Set pDoc = Application.Document
Set pMap = pDoc.FocusMap
Set pEnumLayer = pMap.Layers
Set pLayerSet = New esriSystem.Set
pEnumLayer.Reset
Set pLayer = pEnumLayer.Next
Do Until pLayer Is Nothing
'Enumerate through the layers in the TOC and
'Get the Feature Class Name from the featureclass
Set pFC = pLayer.FeatureClass
Set pDataset = pFC
Set pINFeatureClassName = pDataset.FullName
Set pInDSName = pINFeatureClassName
Set pFields = pFC.Fields
Set pField = pFields.Field(lGeomIndex)
Set pGeometryDef = pField.GeometryDef
Set pFeatureClassName = New FeatureClassName
Set pOutDatasetName = pFeatureClassName
'Assign name to each exported layer
pLayerSet.Add pLayer
For i = 0 To pLayerSet.Count - 1
X = pLayerSet.Count - 1
pOutDatasetName.Name = pDataset.Name & "_Export"
Next i
Set pWorkspaceName = New WorkspaceName
pWorkspaceName.PathName = "C:\temp"
pWorkspaceName.WorkspaceFactoryProgID = "esriDataSourcesFile.ShapefileWorkspaceFactory"
Set pOutDatasetName.WorkspaceName = pWorkspaceName
'Export the layers in the TOC
Set pExportOp = New ExportOperation
pExportOp.ExportFeatureClass pInDSName, Nothing, Nothing, pGeometryDef, _
pOutDatasetName, hWnd
Loop
'Update the table of contents
pDoc.UpdateContents
End Sub
Article ID:000007459
Get help from ArcGIS experts
Download the Esri Support App
