PROBLEM
If a Boolean field has been added to a dataset using an application such as Microsoft Access, ArcGIS converts this field to a short integer and sets all values that are True equal to 1 (True = 1) and False equal to 0 (False = 0).
A Boolean field contains values of True and False only. Some applications, such as Microsoft Access, use the Boolean field type. Geodatabases and shapefiles do not have a Boolean field.
The selection will not return any records if the statement is written as:
Code:
[boolean field] = 1
Use the following statement, as a workaround, to return all records that are equal to a value of 1:
Code:
[boolean field] <> 0
The function <> can be interpreted as any value not equal to 0. Since a boolean field only has two values, 0 or 1, the result will yield the selection of values equal to 1.
Article ID:000004783
Get help from ArcGIS experts
Download the Esri Support App
