PROBLEM
WMS and/or other image service layers do not display when printed or exported
When printing or exporting maps that contain Web Map Server (WMS), Internet map server (IMS), and/or other imagery service layer, image service layers do not display on the output.
Cause
If the map layout page is medium to large size, the output image size being requested to draw the WMS layers to the output print or export file may be larger than the maximum image size served by the image service.
All image services set a maximum X,Y pixel limit for the images served. If an image service is added to an E-size map and exported to PDF at 300 dpi or (34" x 300dpi) x (44" x 300dpi), the image requested is larger than the maximum size served by the image service.
Solution or Workaround
Check with the image service provider to find the maximum x,y image they serve and either reduce the output map page size so that the requested x,y image is within the limits set by the image service, or use other data that is not served by an image service.
    Article ID: 000009248
    Software:
    • ArcMap
    Download the Esri Support App
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Go to download options
