** Internal Publish Only! This article may contain information that is not intended for external circulation. **
When zooming into an AirPhoto USA's 2004 PhotoMapper image, the image disappears.
Cause
This is a known problem with PhotoMapper images that is identified on AirPhoto USA's Web site.
Solution or Workaround
- On the Network drive:
Uninstall PhotoMapper
Install "PhotoMapper 4.2.2" in the same folder as previous version
- On each machine that has ArcGIS 9.1:
Uninstall "AirPhotoUSA MapHandler"
Install "AirPhotoUSA MapHandler v4.23 Prerelease for ArcGis 8.x or 9.x"
As a precaution, do NOT to make a copy of the network license manager .plm file. The LM may get confused if it sees multiple copies on the same server.
