PROBLEM
When running the ZonalStats function at the Grid prompt, 'Fatal Error' occurs
** Fixed at ArcGIS 8.2 **This error occurs when running the ZonalStats function at the Grid prompt:"Fatal Error"
Cause
This is a known problem with large input grid datasets.
Solution or Workaround
This is issue has been resolved in ArcGIS Version 8.2.
In previous versions:
Run ZonalStats to calculate only one statistic to save memory space:
Code:
Grid: output = zonalstats(zonegrid, griddataset, mean)
Article ID:000004903
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
