PROBLEM
When editing joined data, some fields are not editable in the table window
When an edit session is started and an attribute table is opened for joined data, some fields are not editable.
Cause
A field is not editable if it is a joined field or the field in the target layer has the same name as a joined field.
Solution or Workaround
Edit the join table independently. Changes made to the join table are applied to the join.
Article ID:000002967
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
