PROBLEM
When displaying a Layout at a 1:1 ratio, one inch displayed does not equal one inch measured on the screen
When the Layout is displayed at a 1:1 ratio, what the screen calls an inch does not equal a measured inch on the screen.
Cause
All display calculations in ArcView use dots per inch of the screen.
Solution or Workaround
  1. Measure the width and the height of the portion of the screen that is lit by pixels (the measurement may be 12.5 x 9.0).
  2. Open a new script window.
    A. Activate the Project window.
    B. Click the Scripts icon.
    C. Click New.
  3. Enter the following line of code.
    Code:
    System.SetScreenSize Inches(12.5@9.0)
  4. Click the
    [O-Image] Script compile button
    button to compile the script.
  5. Click the
    [O-Image] Run compiled script button
    button to run the script.
    To make this permanent, add the line of code to the $AVHOME\etc\startup file.
Article ID:000003664
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
